- Mar 5, 2019
- Age
- 57
- Islander
So, have not splashed Cow Bell yet....hell, have not started the engines lol. I know they work, I have a video of her running, but, I am debating what next.
She is off at the Fiberglass place having the outer hull totally cleaned up, sanded down where needed, buffed, and all the color blended as much as possible. I felt it was worth the money to remove the stickers myself, then send it to them to remove the old hardware from the bimini and arch that I could not remove. I do not have the arch.. which is a shame...would have liked to give that to someone...but I DO have the bimini.. so, I will get all the hardware back and have that available if someone needs it and comes to get it.
In the meantime, they are going to repair a dime-sized 'notch' of fiberglass that is missing on the back quarter corner. No damage other than it looks like someone hit it and knocked a small piece off. They will be cleaning the transom cap and sealing it and any and all exposed parts of it. That should last a year or three for me to work the funds into replacing that all together. It looked okay, and no apparent damage, just would feel better if it were cleaned up and sealed better.
Then they will repair and patch all the holes from the removed parts on the cockpit.
Then clean up and polish get the hull ready for the new decals.
SO....that brings me to the "next part...
While we wait for the top to arrive....
I am told the water pump and impeller were replaced like 6 months ago and no more than about 10-15 hours on the engines since then. Debating if it would be a waste of funds and time to drop the lower ends and replace all of that... and, what would YOU replace? I cannot, I think... check the exhaust without dropping the lower ends.. so.. in for a dime.. right?
If I drop the lower ends, I may as well replace it all and call it good for the next one to three years, right?
Then, plugs are easy and cheap to replace...
You see the "bunny trail, right? lol
Debating what oil is best for a 2003 and 2004 4-stroke.. brand.. do they make a synthetic blend for boats etc...
Thanks... just looking at what is best, vs what is worth the funds right now.
Russ
Russ
