Hi All;
I have a 93 Adventure with Yamaha 150 (2S) of the same vintage. My marina just switched to E10 fuel and I was planning to use most (if not all) of the MBTE fuel left in my 82 gallon tank before refilling. Since my fuel guage shows "out of fuel" with about 20 gallons left in the tank, I planned to use the boat for 2-3 hours and had an emergency 5 gallon supply on board to get closer to finishing the "old" fuel. I must have miscalculated fuel usage because I pumped 65 gallons of E10 into an 82 gallon tank before it ran out the vent.
Once underway, I had the familiar loss of power associated with a clogged fuel filter, so I spun a new (10 micron) on and went on my way. Less than 15 mintes later, THIS filter clogged - uh-oh.
Long story short, apparently the MBTE and E10 mix created a water-filled sludge for fuel. The mechanic suggested I replace the fuel filter with a water separating unit and said he'd pump fuel out from the bottom of the tank until he saw "good" fuel. He did so and luckily I only "lost" 7 gallons of fuel. So I took the boat out with the clean E10, a new water-separating filter, and high hopes. I saw my gas guage reading empty but thought maybe when the mechanic pumped the bad fuel out, he may have hit one of the sender wires, so made a mental note to tell him about it when I got back.
15 mintes out, the motor ran out of fuel and would not restart. There was no fuel in the glass bowl of the fuel filter so this led me to believe the engine was not getting fuel. I got a tow back in and here I sit... Ideas? Is there anything he could have done - easily - that would explain this? He is a qulaity mechanic and only spent 45 minutes installing the filter and pumping out the bad fuel, so it doesn't FEEL like he touched a lot of moving parts. Anyway, he's on the case and will give me a call, but I was wondering if anyone was willing to hazard a guess as to what might be going on. Thanks to all - this is a great forum.
Pete H
Pete H
