My 232 has twin 2006 Yamaha F200's with 754 hrs. on each.
I normally run with the display of engine temp, battery and oil on my gauges. You all know, the 3 flat lines with the little arrow above each line that moves right or left, depending on the reading it is indicating.
My engine temp, (the top line) runs right in the middle, which I was told is normal. However, when I run over 4100-4200 RPM for a sustained period, 5-6 minutes or more, the arrow moves to the right one notch, indicating a slight overheating, I would guess. This happens on both engines, although the stbd one moves over quicker than the port one. As soon as I drop off plane, or slow down to 3600-3700 it returns to the middle position, to stay there until the next period of 4100-plus.
My tech says this is not cause for concern. He said alarms will start blaring if real overheating is imminent. He also stated that we can put a computer on it, run it and look for the sensor that is causing it, but suggested that I go on and not worry.
Most of you guys run Yams; has anyone experienced this? Would any of you worry about it? Has anyone positively identified the problem if there is one?
Thanks All..Always appreciate the feedback here.
