Was out Saturday all day, ran the engine on idle allot but also moved from place to place. I noticed after a few hours when I adjusted the throttle from idle to about 3500 RPM and tried to trim the engine the engine would start to cut out. So I didn't so that anymore, we were fishing thirty miles from home port and we left there so and I ran at 4800 the entire way home about 35 minutes. Stopped again to fish for a couple hours and then headed in. I noticed that at WOT I could only get 4800 RPM max, but that could be because I couldn't trim the engine up. When I was pulling into the dock the engine cut out completely and will not start at all now. When I turn the key all I get is click, throttle is in Neutral. Had the batteries checked, load tested and they are fine.
Yamaha f225
Since the batteries are ok where do I go from here? The starter? Any fuses in the engine?
Help.
Yamaha f225
Help.
