Exterior Drain Flaps
T_Wrecks
Does anyone know where I can get replacements for the exterior drain holes on a 2005 Tournament 205? I'm missing all three sizes.
Are those through hulls or scupper drains?
If thru hulls, there are no flappers.
I see that Skunk responded already. I had type my reply but for some reason didn't hit send:)
T_Wrecks
Thanks for the replies. These are the through hull drains for the cooler, bilge, and toilet area I believe. The scuppers at the stern are still in place.
So all is OK.
Note that the flappers do dry out and harden over time and should be checked as part of the typical annual maintenance. Also note that some of the Grady scuppers use somewhat uncommon diameter flaps. The kits you find from TH Marine for example, may look correct but may not fit correctly. A difference of 1/16 inch in diameter can make the difference between a working flapper and one that sticks either closed or open.
Of course the Grady OEM parts are an option but are fairly expensive compared to offerings from TH Marine.
