F250 Yamaha 2005 idle
offshore
When I start the engine it idles perfect 600. After running the boat for a while it idles between 8-900. If I shut the engine down and start it back up it idles fine at 600. When running the engine and runs perfect. Any thoughts? Thank you.
Doc Stressor
Homosassa, FL
It's likely a sensor that sending an intermittent bad signal. I would suspect the throttle position sensor. These often throw a code each time they fail.
I would take it to a dealer and have them download the log and any warning codes.
offshore
Does anyone know the part number? Thx agn
Doc Stressor
Homosassa, FL
Before you start ordering parts, you really need to run a diagnostic and look for codes. In addition to the TPS, there are also accelerator position sensors that could be the source of your problem (although I doubt that would give your symptoms). The other possibility is air leakage in the throttle valve cylinder head. The Yamaha shop manual for my engine says to look for a trouble code first, then check the O-rings and gaskets in the intake manifold, surge tank, an throttle body.
offshore
I had a certified master Yamaha technician diagnose the engines and the only code that came up was 72 cam position sensor at 1000 hrs. I now have 1080. I swapped the sensor with the other motor same problem so it's not the sensor. Anyone have any thoughts. Thank you
offshore
jbrinch88
It could be anything from a bad fuel pump pressure regulator and or pump to a bad IAC motor, TPS sensor, or MAP sensor. Hard to diagnose without the laptop out. I would have had the technician check the engine parameters (live data) on each motor and compare. Too many electronics on these EFI motors to just guess.
I know it's unlikely but pull the motor cover off and take a look at the throttle linkage setup. Could be something simple as that.
