- Apr 18, 2024
- Age
- 37
- Freedom 275
I came here today for advice on installing outriggers on my father’s boat, a Freedom 275. He’s looking to purchase a kit centered on the Taco GS280 mount. My summer job as a kid was working at a boat yard, and I did assist on these sorts of installations over those years, and so my father has asked me to see about installing them when I visit this summer.
This isn’t my field anymore (nor ever really), so I’m doing research to support my case when I go to send my father to a professional. I haven’t been able to find a ton of information about installing outriggers on a Freedom 275 online. What I remember is that there are easy boats to install outriggers on, and there are difficult boats. Sometimes you just measure really well, drill the T-Top with a hole saw, seal everything up then bolt everything up in a two hour job. Sometimes you have to weld up the frame a ton to strengthen it, or sometimes you have to weld backing plates to the frame to take the actual weight before you drill the T-Top. (I guess T-top is the wrong word here, but I’m used to putting them on center consoles). Sometimes the top has to be removed for the welding, and that’s a huge PITA. Honestly I could do the first one just fine, I’d just have to look up the correct sealants and stuff. The welding is way out of my wheelhouse.
I can’t find good photos of our hard top on my phone, or where we would mount the outriggers at in photos online of the models either. However, the research I have done and my memory leads me to believe that this particular job requires the welding of backing plates. I do not recalling noticing that Grady White had pre-installed mounting points for them, and do not believe they are there. Is anyone able to advise me on if I’m correct about this?
Has anyone put outriggers on a Feedom 275? What’d you use? How’d it go? Does the top have to be removed? Would anyone be able to give me a guesstimate on the labor cost for the job I hope this is, having backing plates welded on and the outriggers installed? I know what the outrigger kit itself will cost. I know the cost will balloon if the top has to be removed.
