fresh water sink and hose issue? Voyager 248
gradywhite248
Hey guys this might be a screen of filter but tell me what you think? when ever i turn on the fresh water pump in the sink or shower hose the pressure seem good for one second and then slows or spits? I can hear the pump running and the tank is full. not sure where or how to get to the screen? any ideas?
family affair
Ohio
The filter/screen threads onto the intake side of the pump body. It is likely blocked.
Funny how only the Voyagers are having this issue this year! :bang
gulfcoastangler
Not sure about yours but mine was located in a panel in the cabin. When I turned it on same thing happened to mine but it was not the filter. The pump would run and sounded fine but the impeller or something was no good had to replace pump now fine. Just an fyi when I replaced pump all the sinks leaked and it ended up all the plastic fitting grady used were all cracked had to replace them also and that was not fun finding fittings that would work but not the junk they put in. Finally found them at a rv parts store.
