Tom - my replies in context below
I don't exactly follow your freshwater problem description.
Can you please clarify a few items so these fine commenters can better help you?
You have a freshwater holding tank that you can refill using a garden hose or such through a capped fill port, correct? Tom - Yes
This freshwater tank should hold 10 gallons of water and when empty should take around 3 to 10 minutes to refill, depending on garden hose diameter and water supply pressure.
You have a freshwater pump switch, yours may be labeled "Water Pressure," somewhere on the console?
You have one handheld shower sprayer, with a pushbutton control, mounted somewhere near the transom boarding ladder? Tom - yes to all three !
You normally keep the freshwater pump (Water Pressure) switch in the OFF position except when you want to operate the freshwater sprayer? Tom - Yes
When you say the tank is "empty", do you know the tank is actually empty and you can add another 10 gallons (again this should take 3 to 10 minutes to fill) to bring it back to full, or do you mean the sprayer will not spray? Tom- have added water to the tank twice now and the shower head and pump seem to work fine. Tomorrow I will check tank with camera scope to see if it drained empty. The sprayer was originally stuck in depressed button state , I have since fixed that.
IF... You have the freshwater pump (Water Pressure) switch off (assuming factory wiring and that someone hasn't wired around the switch) and the freshwater tank empties over night or say several days, and you require 5 to 10 gallons (3 to 10 minutes) to refill the tank, then the tank is leaking. Have the tank replaced. Tom - ok I will know soon.
IF... You leave the "Water Pressure" switch in the ON position, and your freshwater pump is operating (you can hear the pump motor if you listen), the freshwater pump can empty the 10 gallon freshwater tank fairly quickly (3 to 5 minutes) under these conditions:
a) the sprayer valve is stuck in the open position
b) the sprayer valve is defective (they will freeze and break) and will not close
c) the pump body is broken (they will freeze and break)
d) the water line from the pump to the sprayer is disconnected or broken (these do not normally freeze and break). Tom - I don’t normally leave pressure on. Good point however , while the shower head was stuck in button depressed mode , it’s feasible that we could have accidentally put water pressure on when running , draining the tank with the shower head not even pulled out of the receptacle. Hmmmmm….
IF...The water tank is full or near full, the Water Pressure switch is in the on position and the circuit breaker has not been tripped, and when you press the sprayer valve button you get nothing, then the freshwater pump is most likely bad. First confirm good positive and negative power connections at the pump and correct as needed. If you have good power and ground at the pump, replace the entire freshwater pump. You WILL NOT hear the freshwater pump running under this condition. Tom - just after filling tank with a gallon or two of water and after fixing shower head the spray is fine and pump stops when I let go of sprayer button.
IF...The water tank is full or near full, the Water Pressure switch is in the on position and the circuit breaker has not been tripped, and when you press the sprayer valve button you hear the freshwater pump motor running and still get little water flow or only a "gurgle" sound, then the following conditions may exist:
a) the fittings on the water line leading from the freshwater tank to the freshwater pump may be loose and allowing air to enter, and not allowing the pump to prime and pump water. The likely loose fittings are the ones connecting the water line to the strainer screen, the strainer screen itself (they will freeze and break), or the connection from the screen to the pump. Inspect, tighten or replace as needed. This condition is unusual unless someone has been "working" in and around these components (except for freeze damage)
b) your freshwater pump is most likely bad. Replace the "wet end" of the pump, or if existing pump is original to the 2014 build, replace the entire freshwater pump.Tom - not the case at all !
Tom - thank you !
