Fuel Gauge Problem
Freedom275
Hi. I apologize if I’m not supposed to post “repair” questions but I replaced both of my batteries a few days ago and all works well except the fuel gauge does not turn on. Not even one bar. I filled up the tank with 100 gallons and still no display. Is this a fuse problem or a “sender” issue and what’s the best way to attack it? Thanks in advance.
Nothing wrong with posting repair questions - they make a good portion of the forum questions.
There is no fuse for the sender. I agree with Skunk. If all you did was replace the batteries, then the most logical thing is that you didn't re-hook a wire or possibly even put a wire on the wrong post. Hopefully you're not dealing with "one of those boats" where some owner wired tons of things direct to the battery!
A few basic questions first:
Is is correct that the gauge worked before the batteries were replaced?
When you say no bars, I assume you have the digital gauge. That should go through self test when you power up. All segments with display. If not and it worked before, you probably have no power. If you have two guages, spedo and tack, both should go through power up self test.
If all these things worked before, you messed something up with the battery swap. One of the more common mistakes is leaving off the short black cable that ties the two batteries together. Check that there are no loose smaller size black cables laying in the bottom of the battery compartment. That will be the accessory master ground.
You may have also inadvertently popped the accessory breaker that is near the batteries and has a red reset button on it.
My bet is that you find a cable disconnected near the batteries.
