- Apr 23, 2019
- Age
- 70
- Marlin
One of the issues I am trying to fix is the fuel readings at the helm. The main tank reading shows one bar and does not change. The aux shows and accurate reading but takes an excessive amount of time to change. I assumed it was the senders but in testing found otherwise. Shorting the aux sender contacts showed a full tank but did take to long to read. Shorting the main sender contacts still showed no fuel, ie one bar. On a hunch I jumpered the ground contact on each tank to the neg bus in the bilge and both tanks senders worked perfect in both test short and normal function from the helm switch. So far I have only inspected through the pie hole. My question, is there an easy way to run new ground wires without pulling the deck panel. I have already tried a wire brush on the tank contact/wire with no change.
thanks
thanks
