- Jun 29, 2020
- Age
- 43
Captains,
My 1999 272 Sailfish has some dated (maybe original?) equipment (Raymarine A65, Raymarine C80, Raytheon Pathfinder SL70) which I would like to upgrade. I am not 100% sure what transducers and receivers it has, but I can go through the manuals. I've had touchscreens on previous boat, so now they feel essential.
I fish out of Atlantic City, NJ. Bays/inshore (flounder, stripers), wrecks (sea bass, tog, 10 - 20 miles out, 45 - 175ft), mahi (pots around 20 - 30 miles), and will go for tunas offshore approaching the canyons (60 - 80 miles) as I am able to build up the confidence, etc. with this boat. 200 gallons of gas, yamaha 0x66 2 strokes... so u get the idea of my range.
I contacted a local professional installer and had him give me an estimate for top end SIMRAD, which i have attached. Soup to nuts it's $11,820.35. Now I'm looking to potentially dial it back a bit after a friend said it is overkill for me (see below).
In his quote the main items are:
For context, here is my buddy's reaction in full:
Toglips calamari,
Captain Dan
- SIMRAD NSS12 EVO3S COMBO RADAR BUNDLE W/HALO20
- XSONIC B275LH-W Wide Beam CHIRP, 1 kW, 9 Pin Connector
- SIMRAD GS25 GPS ANTENNA
overkill unless you plan on doing a lot of deep water wreck fishing &/or a LOT of canyon trips running 75 miles in the dark
The effective radar range on your hard top is probably 24 miles - a little farther for thunderstorms. when you run in the dark, you spend most screen time at 3 miles, occassionally looking further
that transducer is ideal for a much bigger boat at 30+ knots
You’ll spend most fishing time looking at the sounder at trolling speed or less
In the canyon, you’re only looking closely at the first 250-300 feet. You can still see the mud bottom spots where the tilefish live in 350-700 feet
Toglips calamari,
Captain Dan
