Gel coat damage
Cdorf
How to handle gel coat damage
Stare at it with one hand rubbing the back of your neck and the other on your hip while muttering incoherent mutterings mixed in with abrasive cursing.
You're going to have to give us more info.
Reactions: Bg56126
Depends on the actual damage. Small scratches can often be buffed out. Deeper but still narrow scratches/scrapes can be filled using color matched (Spectrum Color brand) paste.
Larger gouges usually need to be ground out and then patched. Finally if the glass fibers are exposed, a more complex process may be needed.
That said, if you don't care about the color match, MarineTex is a simple way to fix small to medium damage. With all fixes, there will be sanding, compounding and polishing if you want the repairs to be smooth
As DennisG mentioned, more info in the form of a few pictures will get you better responses.
If minor you can get a small bottle and touch it up till it is proud of the surface, then lightly sand down flush.
