Generator recommendation for 330 Express
jcherubini
Barrington, RI
Hi Everyone,
I have a 2005, 330 Express which needs a diesel generator replacement.
I am trying to get away from replacing it with a Fisher Panda and was wondering if anyone could reommend another make/model that would physically fit into the boat given the tight clearances.
Thank you.
Jim
mg1826
Madison, CT
Hi Everyone,
Thank you.
Jim
Good morning Jim,
I have a 2007 330 Express and the Fisher Panda was replaced last year with a Next-Gen marine generator. So far so good with it and I haven't had any issues. It sits in an enclosure that helps mitigate some sound and vibration. My boat is also located in RI if you wanted to see it.
Reactions: LadyG
I'd do some research and look for size compatible units. I'm sure there are a few out there by now.
LadyG
Good morning Jim,
Who did your install? I’m prepping to do my NextGen soon.
LadyG
mg1826
Madison, CT
I had it done at Safe Harbor in Westbrook, CT. They had a tech that specialized in generators and made a pretty easy swap for me.
everwhom
Cape Cod and Nantucket
Depending on how you use it, you might consider replacing with an inverter and Lithium Ion battery bank. I don't use much 110v power (no Air Con use) and I replaced my FP with a Mastervolt inverter + small battery bank for a small fraction of a new genset. Couldn't be happier!
I'm certain this will be the future even for serious 110v power use.
jcherubini
Barrington, RI
Wound replacing it with a brand new diesel NextGen UCM1-3.5.
Did everything with Scott at Noreast Marine Services out of Fairhaven who is a NextGen dealer. Scott came to where I store the boat in Allens Harbor, RI and was great to work with. Crystal in the office was great to work with too.
1 Adams St, Fairhaven, MA 02719
(508) 994-1781
NassauGW
Nassau, The Bahamas
(508) 994-1781
Great to hear, has 3.5kw been enough from the 5kw? The main thing I’m worried about is running the AC. Considering nextgen or a phaser 4.5kw
Nice. Let us know how she performs.
