- Oct 16, 2007
- Age
- 70
- Cape May, NJ
- Islander
Starting a thread here to document my live underwater camera. This is my Winter project for fishing in clear water in the Keys. I searched for cameras and came up nothing I liked. The GoPro is a high quality inexpensive camera but it's really an action camera. It can be adapted to work but isn't always easy.
It's easy to jamb a GoPro camera in the water and record video. It's not so easy to get the live video to the surface where you can connect it to your chartploter.
I'm taking the approach of using a Suptig waterproof housing, GoPro Hero 9 and GoPro Media Mod.
GoPro has a Media Mod that wraps the camera and provides HDMI output but the mod won't fit in the waterproof case. It has a USB C connection to the camera inside the case and external connections to micro HDMI and USB C. The Media Mod will be remote from the camera behind the chartplotter. The two are connected with a long USB C cable that is connected to the camera with a waterproof connection. The Media Mod connects to the chartplotter HDMI and to a USB C power source.
Camera will be mounted on an adjustable length Shurhold pole with a GoPro adapter. Shurhold pole will sit in Cannon rod holder angled behind the boat. The idea is to keep it simple to setup and use otherwise it won't! We will learn a lot first trip out and make adjustments.
So far I have cabled everything up and tested camera with the chartplotter. Working fine. Garmin lets you display the video on either chartplotter. Image can be mirror and rotated if needed. Had to install a GoPro Labs modification to display "clean" HDMI video without any controls or information. That is working fine too.
We'll see!
We'll see!
