- May 9, 2006
My rubrail has turned white in spots from wax that was meant for the fiberglass and got on the blue plastic anyway. The sun over the years also made it turn whiteish.
I found something that works pretty well to return the rubrail to blue.
Peanut butter....
That's right...peanut butter (smooth; not crunchy)
Try smearing a thin coat on your rubrail. I leave it for 10 minutes and scrub it off with a brush and soap and water. Then I follow it up with a good wipedown with a magic eraser; and lastly a washcloth wet with plain water.
I'm not sure if the result is better when you leave the peanut butter on for a longer period; or if you massage it in more with your fingers.
I hope someone could report back.
Peanut butter....
