- Dec 31, 2024
- Age
- 64
- Trophy Pro
First off thank you for letting me join your site. I recently purchased a 1989 Grady 25 ft Trophy Pro. Can someone tell me where and how to find the wash down pump.
I am not sure where the inlet valve isfollow the hose from the inlet valve
that might be why you have no water.I am not sure where the inlet valve is
Yes the pump doesn’t work that is why it is so hard to find itProbably mounted somewhere to the inside of the transom. If you don't know where the inlet side is, follow the hose from the output side. Or if it's working, turn the pump on and see if you can hear where the sound is coming from. If the boat is on a trailer, you can look under the boat and see where the thru-hulls are to pick up the water. That will also give you a starting point on where the inlet side is.
That hull is 36 years old. Odds of it being the original pump are about zero percent, so one of the previous owners could have replaced it with something different and moved it.
Does not runIf it runs, turn it on and listen for it. It usually a small Blaster pump.
Boat is on trailer, I looked in all of the 6” plates and can not see anythingthat might be why you have no water.
It's going to be in the deck at the stern of the boat.
Is the boat in the water? If the boat is in the water, don't open the valve. Get it on a trailer and check things out.
Often Grady put a 6" piehole for access to valves. Often there was a knob with and extention rod. I would suggest removing the deck entirely and look at it.
Look at the bilge pump and float switch and everything else. Make sure it works.
Yes that is what I am looking forJust to clarify - I assume you're looking for the SALT water washdown pump. If you have one, it either gets saltwater from a dedicated thru-hull valve or it is a Tee'd off connection from the live-well pump. Follow the salt water washdown hose to the pump. Then follow the pump inlet hose to the saltwater source.
If it has SW washdown and /or a livewell then it has one or two holes with bronze (or plastic) strainers in the bottom of the boat near the stern.Yes that is what I am looking for
