- Jun 14, 2021
- Age
- 39
- Voyager
Hi everyone, I’m looking to get some information from voyager 248 owners or prop experts.
I have a 1999 248 voyager with a single 225 evinrude etec. I have tried two props.
boat is bottom painted, paint is not really smooth.
Tested with only 15 gallons of fuel and two people on the boat. Flat calm inshore +- 1mph current.
no ice or extra weight on the boat.
Engine is mounted at highest position(I think it could be higher but I have no more higher positions in the engine Mount, after trimming the motor still see some water splashing up)
Test results with motor trimmed up
Viper prop 14 3/4” x 17” pitch
Cruise at 4600rpm 26mph 2mpg
WOT 5650rpm 37mph 1.6mpg
Rebel prop 15 3/4” x15 pitch
Cruise at 4600rpm 31mph 2.2MPG
WOT 5350rpm 38mph 1.8mpg
The boat got on plane just fine with both props. I also have a hydrofoil on the lower unit of the motor.
what would you guys recommend me to get I like the performance I get with the rebel prop. but I’m worried I’m putting too much load on the engine specially when I put weight on the boat.
i think that after I put 8ppl on the boat and load it up my RPMs are going to drop below the operating range.
manufacturers recommended operating range 5100rpm to 5800rpm
5600rpm is the sweet spot.
