Grady White Freedom 235
jchip14
I have noticed that Grady White lists fuel tank sizes for Freedom 235 as 100 and sometimes 115? Which is it? Also for owners, what is GPH running at normal cruising speeds ( 3500-4000rpm) thanks!
McBobKC
Venice, Florida
I called and asked GW that question on my 2024
Response was
The Fuel Tank is 115 gallon, HOWEVER, not all 115 gallon will be useabl, thus, Budget / Plan toward 100 gallon being available
If you pop the deck plate over the sending unit there should be a label.
jchip14
Response was
Thanks. Odd - why some of it not available?
McBobKC
Venice, Florida
In aircraft there is always a difference in tank capacity versus usable fuel - tank angles, etc toward being able to reliably deliver fuel consistently to the engine
