Hello
I just bought a used 2005 Gulfstream in Sept. The boat is real clean looks almost new. I went to use the fresh water pressure pump today and it did not work. I look in the maunal and it said the pump is located under the passanger seat. I took out the draws and located the fresh water storage take but could not see any pump. I traced the hoses and saw they led to the rear of the boat and saw the pump near the batteries, mounted on the rear wall next to the salt water wash down pump. Question does this mean the previous owner moved it here? Was there a problem or did GW make a mistake in their diagram?
Also is it the same type of pump for the fresh water as they use for the salt water?
Thanks in advance.
Bill
Thanks in advance.
Bill
