- May 15, 2021
- Age
- 63
- Burlington Vermont
- Gulfstream
When I purchased my GW 232 with twin 150’s last year I was told the starboard throttle and shift cable was replaced. Not sure why both weren’t done in pairs but that is another story. During the summer noticed both idle at the same rpm but when moving forward the port engine lags rpm’s (nearly 1400 rpm’s at full throttle). Both engines run smooth. Babied it and ran both at the same knowing I would get resolved for 2022.
Engines are original with 1280 hours. Have looked at linkage and nothing noticeable. Research showed cable could be stretched or worse in areas I can’t see. Replace one or both cables at this point? Anything else to consider? Note no other record of cables having been replaced in documents provided.
Snow starting to melt so ordering parts for 2022!
