- Oct 5, 2020
- Express 265
Greetings to the more experienced than I -
I am looking for my first boat for my family, cruising, fishing, diving, snorkeling and have a good amount of time on the water (primarily sail but a not insignificant amount on power) in the 27-40 foot range. I have a contract on a 2000 GW 265 express with twin Yam 200 HPDI's. The boat is in 'decent' shape, needs a little work and the price is pretty competitive. My concern are the HDPI's. About 800 hrs but mostly Idle time, i.e. idle to the inlet, idle to weed line, idle along the weed line, idle home; sit for months on end since the owner is 1200 miles away. Every now and again open it up to make sure it goes fast. The boat is also stored in a slip on the intracoastal in S. FL. Based on what I"m hearing about the HDPI, it shuts down two cylinders at idle and can gum up the rings on the lesser used cylinders. Otherwise the boat is a 20 yr old boat with a few dings but not beat up. Needs a few things starting with a good compound and wax.
On the other hand I've been eye-balling a 2003 Edgewater 265express with twin Yam F225's. 2K hours on one, 1400 on the other after a new power head, both had the exhaust manifolds replaced. Boat is clean, really ample space, love the aft bunk and port in the head. Boat is also in FL, stored on a trailer in a warehouse and locally owned by a single owner. Never bottom painted.
My two main questions are thought's on the GW's HPDI's, since it seems like the usage pattern may be a bad thing. Extent of usage on the F225's on the EW. General thoughts on the ride of each and the value of purely dry stored v. sitting in the water. It's my understanding that the owner of the GW, did keep up with the HDPI's maintenance.
Thanks in advance!
Thanks in advance!
