I'm installing a Yamaha Fuel management system on my 1999 228 Seafarer with a 225 OX66. The instructions that came with the fuel flow kit (6Y5-W0088-55-0) and the original rigging guide show an optional part that sits between the fuel tank and fuel flow sensor. The wiring harness that came with the kit has two leads to connect to this mystery device. The kit instructions have a note that says, "If the fuel line is used for a kicker supply, be sure to install a valve in line or sensor ventilation could occur."
This mystery part is obviously some sort of check valve / anti-siphon device. I do plan to install a kicker so I want to get this setup right now. Does anyone have a part number for this mystery part?
