- Oct 12, 2017
- Manasquan Inlet NJ
- Website
- www.youtube.com
- Express 265
I needed to raise the height of my All-around white after raising my radar dome.I also wanted to go to LED.
I had a Perko 12" that had a quality reinforced plastic adjustable base. Much searching online and at West Marine found nothing suitable. All of the bases are really cheap plastic GARBAGE and the size goes from 12" to 24" and I just needed about 18". Also there are a couple types of LED out there and some aren't really even 360deg. Some don't have a replaceable bulb.
I ended up buying a 3nm LED on amazon https://www.amazon.com/dp/B07GDJCYV2?ref=ppx_yo2ov_dt_b_product_details&th=1
The length didn't matter because I made my own mount. Drilled out the rivet and just used the light part.
I used 3/4" pvc pipe and thread couplers from Home Depot. I used silicone to glue the light fixture to the coupler. I painted the pvc fighting lady yellow to match the underside of the hardtop. The 3/4" coupler has a 1" thread that fits an antenna mount. I used a short stainless mount that I had laying around. I wired it with a plug so I can unscrew it for trailering at the end of the season.
On my previous boat I used a "Lift-N-Drop" type antenna mount and the pvc was about 30" and doubled as a flag pole.
