- Jun 30, 2008
- Ocean Pines, MD
- Express 330
Ran new AWS12 wire from back of old stereo in 330 Express to behind the panel. I’m upgrading to new Fusion stereo and thought I’d run new wire since I was running NEMA and new speaker wires.
Anyhow, I pulled panel and hooked up NEMA 2000 to fuse block on back wall. I’d like to tie in to stereo switch in panel which has a 10 amp fuse. I see where the positive wire goes but where do I connect the negative wire and ground? Do I even need the ground?
Attached is where I think I need to attach the positive and negotiate wires. Is this correct?
