- Feb 2, 2012
- Express 265
So...........After developing a nice lil hole in the top of my front tank I finally got all the fuel out to start the process of removing the old tanks. Let me tell you, disposing of anything more than 5 gallons of bad fuel in California is impossible!! I had to get rid of 120 so i burned a bunch after continually emptying my fuel water seperator, (Thanks for the tip on that) but in the process i think i gummed up my injectors. Port motor is now having issues. Anyway that is a later problem.
Today I puled the old tanks. It went fairly smooth. The rear tank had six poly hold down blocks that were screwed to the walls. Once those were removed, along with the 2 x 4 cap on the back bulkhead, I was able to pully the tank up by attaching a 4:1 to the top rail on the roof. Once above deck i propped it with 2 x 4 's then scooted it to the edege of the boat, flipped it on edge and eased it down to the ground. One man job, probably shoulda been two but hey I made it work.
I then had to access the front tank. Lemme just say this is much more of a chore. There are four poly blocks holding that tank in place and a bulkhead made of two 2 x 4's. I was able to remove the screws in the bulkhead and remove that.
Next the poly blocks. Let me just say, the back two are impossible to get a screw driver to. There's only 4 inches between the tank and the bottom of the compartment of the fish kill box. Soooooo.......I just used a sawzall and cut the screws on the back side of the block. My plan is to move the blocks back about four inches to be able to re-assemble. Shouldn't be an issue.
Next.....................
