Islander 268 fuel help
Cedarman
Hey all,
I am newer to the community. I have a 99 268 Islander with new twin 200 mercs. I am very happy with it especially after the repower.
I am having issues with my fuel system and am hoping one of you has the knowledge I need. Currently we only run on the one tank. fill closest to the bow. My understanding is it is a 135 gal tank. The rear fill is for the reserve 65 gal tank. Am i wrong and have this flipped? The tank with the rear fill is full of bad fuel and i need to drain it which is why i do not use it
recently my boat stopped registering my fuel level which is very concerning and i'd like to fix it asap. Does anyone know where the fuel sending unit is and which one my boat requires? my local shop did not know and suggested i come here for an answer
Thanks all!
Can you use fuel flow from your Mercury on your MFD? At least Suzuki and Yamaha are spot on.
If you are lucky the part number is visible on the old fuel sender, if not then the best way to get a new fuel sender is to pull the old and measure it's depth.
Chris
Chris
Hi Chris, Yes my Electronics show my burn rate. around 7 gals per hour for each motor @ 30 mph. My first concern is am I running off of 135 gal or 65 Gal. Next is location of the sending unit so I know which part of the boat to cut open to get it. Rear dance floor or between the front seats on the floor
Thanks for the reply though
I use for many years the fuel level from engine burn, not from the notoriously unreliable fuel senders.
When you refuel you add the correct value and then the digital gauges show level oand in the upper right edge the remaining fuel is shown, but on my Garmin 74 and 84 series.
I don't know your boat but i never saw a boat where it is needed to cut a hole to get to the fuel senders, they are usually be under a "pie plate", the round plate on the floor. Pry or screw it/them open and you will find the fuel sender below.
Chris
Below is a thread I created on replacing fuel tanks on a 1997 Islander 268. It pretty much explains everything you need to know. The forward tank is 134 gallon main tank. The aft tank is the aux tank which is 72 gallons in my boat.
You need to get the length of the sending unit. It's located under the pie plate in the forward part of tyour cockpit. They have to pull it out of the tank and measure it. Replace with correct length WEMA sending unit. I can't find the length in my notes.
If its like every other boat, There are 6" pie plates at each end of each tank.
The sending unit is under the rear (toward stern) pie plate of each tank along with the fuel pickup hoses
The fuel Fill/vent hoses are under the fwd pie plates.
There is a label on top of each tank with its capacity.
The pie plates allow you a peek but it would probably be better to pull up the deck. All you need is a razor knife and a screw gun.
1st... if what you posted about the local shop is true... never go back there again. Replacing a fuel sender is one of the EASIEST things to do - and also very common. It's inline with replacing a spark plug in a 1990 Chevy truck with a small block.
You shouldn't have to cut anything open - either an access plate or a screwed down hatch would simply be removed. Remove the fuel sender... take it with you to a local shop (NOT the one you previously mentioned :) ) and then go back and re-install.
However, it would be prudent to first double check and test the sender wires going to the dash by grounding the pink wire. If everything from the sender to the gauge is good, then the sender is bad.
If you have a WEMA style sender, you may find a part number on it. I can't recall if the arm-style does... it may depend on which particular brand is in there now.
Did the gas gauge work correctly after the repower? The following test is valid for standard tank wiring. Some boats with Mercury rigging and command link instrumentation use a different wiring arrangement for the level sensors and trouble shooting is trickier.What displays/gauges do you have for the motors. Did you have the ability to display both tank levels, one on each gauge?
Before assuming the sender is bad make sure the dash switch that selects one of the two tanks is in the correct position. You have a sender for each tank but the dash gauge can only display one of the tanks at a time.
When you pull the pie plate and see the sender, you will see a pink wire connected to it. If you unplug that wire the gauge on the dash should read empty (give it a bit of time to settle). If that works, connect the pink wire to a good ground. The dash should read full. If those two things don't check out, the problem may be in the wiring, the gauge or perhaps the tank ground
WEMA senders are now made by KUS.
sorry i think I need to clarify, I do not have a analog gas gauge. I have 2 Lowrance HDS 9's and the Larger mercury smart gauge. These are all connected together through the nema network. When we purchased the boat it had etec's (same electronics less the merc gauge). Yes the digital gauge worked before. After the repower the digital gauge did work for a very short time. Now it shows empty all the time.
Thanks for all the help so far
Ok that changes everyting...
When the fuel consumption based fuel level worked after the repower then something may got reset during winter.
Check first on your Lowrance (what i can't help you with) if the HSD9 is showing fuel flow, if so then the HDS9 is getting fuel flow data.
in this case i would first check the settings on the HDS9, there is most likely some wrong setting.
If you can't see any fuel flow realted data on the HDS9 then there may be a problem with your new Mercury engines not ending fuel flow data and i cant help you with Mercury either.
Can you see fuel flow on the Mercury Gauge? If so then the outboard/s send fuelk flow data and the problem is again wither NMEA2000 connection between Mercury and Lowrance or again a Lowrance setting is wrong.
What Mercury engines you have? Can they send fuel flow data?
You are writing of NMEA2000 network, not the old NMEA183, correct?
Chris
OK. Look for the pink wire and short it to ground. See if the gauge reads full. If so, the sender is probably bad
No worries. The initial check is still exactly the same - regardless of what things downstream are reading the signal, the float is still the same 'ol thing. Start there.
