Isotherm fridge stopped working???
grady33
Ocean Pines, MD
was working behind the fridge area in my 06 Grady 330 and went down to not today and fridge was not working. Checked all connections and light doesn’t come on. Has anyone else had problems with their fridge? Any tips? I’m thinking it could be the electronic unit.
Start simple. Probably a FIT - "Failure Induced by Technician"! Is this a 12VDC/120VAC unit? Measure power at the back of the unit with a voltmeter. Go from there.
What did you do to the unit to think its an electronics unit? Did you disconnect it to work behind it? Is it turned on inside the box?
Reactions: grady33
grady33
Ocean Pines, MD
Well it looks like I made a rookie error. The red battery line must have come off and I accidentally plugged it into the wrong connector. Good news is the fridge is working again. Thank goodness because those fridges are expensive! Thanks for the help!
and you were wondering why whenever you ran the mid bilge pump, your beer got cold!
