- Jan 23, 2022
- Age
- 73
- Freedom 335
I have a 2019 335 Freedom with 3x Yamaha 300F with less than 200 hours on the clock.
I have repeatedly experienced steering malfunctions when leaving dock or coming back, ie at low speed in close quarters. Generally it has happened without using the joystick but taking off and using the two outboard motors to steer with. Center motor stays idling. The motor runs but the steering is locked or works for only one or two motors. Always either port or starboard engines lock up.
I don't have a thruster so it is really painful to get the boat back to dock, the marina guys do a good job in assisting.
So I asked the Yamaha guy at the FLIBS about it and he recommended to check batteries as it often is a question of low battery, well not in my case the boat this morning came off the charger and it still happened.
He also showed me a retrofit kit that would replace the hydraulic ones with an electric rams at the motors kind of like the new motors have.
Anymore experience with this issue as I have not yet contacted a dealer but I am under warranty still and I hope it would cover also the steering parts and not only the motors.
actually Yamaha may be more appropriate to contact than dealer.
h
h
