Today I mounted a used Yamaha T9.9 extra long shaft kicker onto the kicker bracket that was on the boat when I bought it. When I stepped back and took a look, I suddenly realized that there’s far too much distance between the front of the main 250 hp engine and the front of this kicker. A threaded rod with a ball clasp on each end will not work to tie these two engines together.  What are my options for steering? If I locked the kicker in place, and use the main engine as a rudder, I question whether I’ll have enough steering authority. I could sit on the back and steer manually, but then that keeps me from doing what I should be doing. The steering really needs to be done from the helm so that I can work the downrigger’s, etc.
I did not see this problem coming and I’m wondering what the solution is. Anyone found one? Would an L-shaped rod work with a pin on one end and a ball on the other? If someone has fabricated something, I would love a photo. thanks very much fellas.
