Livewell Washdown Diverter Valve Leaking
Seaford, Va
Hello,
I have a 1991 22' Tournament and the Diverter Valve for the Livewell and Salt water washdown is leaking.
Can this be repaired.... seals, orings etc....?
Does GW sell this part for replacement.
I would like to repair it as it's not leaking bad but.....it's leaking.
Does anyone have any experience with this valve?
Thank you, Joey
familyof5forhim said:
Hello,
Thank you, Joey
If it's the Bosworth "Sea-lect" brand valve, I've replaced a couple of them.... mostly because they've cracked.
I'm sure the Grady dealers will have them, but you'll pay premium.
I've bought them at local marine stores, (not BW or WM).
Here's one source - http://www.go2marine.com/product.do?no=86250F
Looks like you can get parts - http://www.thebosworthco.com/product.ph ... 4&Num=&S=0
Shows a diagram when you click on "replacement parts", left side of page.
I replaced mine with a bronze 3-way from McMaster (4373K54). You have to make a bracket but you will not have to worry about it again.
