- Sep 24, 2019
- Age
- 71
- Marlin
Here is a short history of the boat and motors before explaining my problem. I purchased this boat in 1996 and am the second owner of the boat. I replaced the 2 stoke motors in 2003 with 2002 Yamaha 4 Strokes. The boat and motors have been yard maintain for most of the time. Since I have owned them I have had no real issue with either the boat or motors until now.
The boat went in the water the beginning of this summer (June 17 2019) and immediately had problems getting the port motor over 3000 rpm. I contacted a local marine to assist with this issue. After they diagnosed my problem they determined it was a fuel pressure issue. I had replaced as normal maintenance the water separator filters and fuel filter. This did not seem to help the problem and the marine at this point suggested replacing the filter (screen) in the VST tank along with the HI-Pressure pump and cleaning the tank. At this time they also replaced the spark plugs at my request do to the fact they were two seasons old. Boat went back in the water and ran fine for a day. The next day it went back to the port motor not getting above 3000ish rpm. This started what was to be a full summer of 'Try This It Should Help'. Some of the attempts to correct this were, running the motors on remote tanks to eliminate gas or fuel line issue at the gas tanks. Remove water separators at two different times to check fuel content and quantity in the filters. Also checked electrical, both at the console and in the motors to rule out possible issues with the computer and ignition switches. Check throttles as well to make sure there was no problem with linkages to motor. During one of the sea trial the mechanic thought I might have spun a prop so I brought it to a local propeller repair shop and had a new hub installed.
This continued for the entire summer at which point I decided it was time to get another marine involved. The marine technicians at the new marine ran the motors as well as pressure tested the fuel system and came up with the same conclusion that the problem is lose of fuel pressure. There recommendation is take care of the motor first, i.e. check the reassembly of the VST tank as well as fuel lines. Secondly remove the floor and replace the fuel lines from the tank back to the motors. Also removing the Grady White installed primer pumps and replacing with hand pump assembly.
Also what I thought was an important item mentioned to me by this new marine was before spending time and money to correct this issue was to check for possible corrosion that the late model Yamaha's were prone to. They pulled the thermostats off to visually inspect and determined it was minimal.
If there is anyone out there that has had similar problems with there boat/motor fuel system I would appreciate their experience and fix.
P.S.
This was my first full summer of retirement and was looking forward to boating on a daily bases, NOT.
P.S.
