Magnetic Cushions?
GradyGuy3420
I’ve been seeing magnetic cushions on CCs vs. the traditional snaps. Seems like a much better option as long as the magnets are strong enough.
Wondering if anyone has retrofitted their cushions to be magnetic and, if so, which magnets, what was the process, are you happy, etc. Also, does it interfere with your compass at all?
Thanks in advance!
Reactions: A&J Outdoors
Magnets... ferrous iron and steel: I wonder if this could become a rust stain problem.
I did something kind of similar on one my previous boats with the cockpit entry door - not huge, but about 2-1/2' high by 18" wide. Normally, it was held "open" with a nylon strap and a snap. But it was never "tight" so it still jiggled. I bought Nd magnets from K&J online. I drilled a hole in the door (backside, where it would touch the fiberglass "wall" when opened) with a Forstner bit and sunk the magnet in the hole so it was flush and used PC-11 to keep it in place and also cover it to make it roughly invisible and to protect it from the elements. Then I glued another magnet on the inside/backside of the "wall". It actually turned out pretty slick.
I think you'd need a lot of magnets to avoid the cushion sliding out of place under the stress of a person's back and rough seas, but it sounds doable! It's not clear from what you wrote, but if you're talking about a seat "bottom" cushion, I think that would stay in place even easier.
Thanks for the reply.
That concept is exactly what I've seen/what I'm thinking. Drill out slightly at the four corners of the fiberglass base/seat and sink one side of the magnets in and seal it off flush with epoxy, while the other magnets are stitched into the bottom sides of the cushion.
Mostly thinking for the seat cushions that have storage underneath them. Snapping and unsnapping four (or more) snaps every time we go into those storage areas...there has to be a better way!
If the fiberglass isn't too thick, you can just glue them on the back side like I did - Nd are very strong - and you pick and choose the strength you want. I suspect you would need more than 4... but it's easy enough to add more if 4 doesn't work as well as you like.
Good ideal. It's all in the execution.
Solas is one of the boat manufacturers who uses magnets to keep cushions in place. Really great idea. They also put magnets embedded in the gunnels that are paired with drink holders.
I’d love to learn how to retrofit this into my 2016 Grady.
There are thin epoxy coated Nd magnets on Amazon with a countersunk hole. I'm thinking of riveting the magnet to the loop where the snap was placed and screwing the other magnet to the deck where the snap mate was screwed. There are some as small as 1/2 inch diameter, then 0.63" diameter, and 3/4". If I recall correctly, the 0.63" ones are rated at 5 lbs. I'm going to give it a try and will report back.
KISS - I have lots of snaps. Enclosure snaps, tonnou cover snaps, seat snaps, cushion snaps. This tool is at the helm all the time. After you loose an expensive cushion you can decide the best approach.
The 2007 Sailfish and other Grady's around that era use a magnet to hold the cabin door open. I haven't paid any particular attention to mine, but it still shines bright and is rust free. So I presume there to be a way to make (and buy?) magnets coated for the marine environment?
