‘yes you hear engine revs go up and see on display they go up from 2500 to 3200
. But I do not hear that sucking sound of props sucking air from surface.
When you are testing..
Are the motors trimmed IN
all the way when you are at a stop and are the trim tabs UP (doing nothing)?
You should accelerate from a stop with motors tucked in and no trim tabs, then trim the motors out as you come on plane.
If you accelerate with motors part way out you may over-rev/suck air.
Are you sure that your motors are set to allow you to tuck them all the way?
Years ago on this forum someone said that their Suzukis were set to stop at vertical and had to be reset to tuck all the way in. IDK if that is true but it was said. My 200 zukes will tuck all the way in and
I have to tuck them to take off.
When they are tucked, it jumps up on plane quickly and then I slowly trim them out as I accelerate.
IMO test your props with no trim tab. Make absolutely sure they are all the way up and then don't touch them. They just add a bad variable to the testing. Your boat should work fine using the motor trim and
no trim tabs.
What diameter are the props? 16 dia x 21.5 pitch x 4 blade props are really "big" and I can't imagine they could ever over-rev if they are in the water. I would think they would be hard pressed to get you up to the top rpm range.
Proof of that is that Harrysea needs 16x17x 3 blade props to reach 6000rpm
Suzuki tends to go with 16" props because the motor is geared lower and able to put more torque to the prop
Suzuki makes 15.25 diameter 4 blade props. Is that what you tried?
By adding a blade you generally have to go down in pitch and/or diameter. The point of 4 blades is to have 3 blades deep when one is near the surface vs 2 blades deep.
Going down from 16 dia to 15.25 also helps by making the top of the prop lower by 3/8". They are less prone to grab air in turns and in rough seas.
As for 30" shafts. JUST SAY NO! Tell them to get the right props! (Try the 3 x16x17 like Harrysea)
