I took out the boat (268 islander w twin 150 hpdi Yamaha's) and after the second drift I noticed the starboard motor was hard to start and then kicked out a quick burst of blue smoke. Once the motor started it ran fine, just gave me a little trouble starting.
I noticed a tiny puddle of oil sitting under the motor while tilted all the way up on the transom before I started the motor. I took the cowling off and it appeared the oil was dripping from the small reservoir mounted to the motor. The oil level in the reservoir was within the maximum/minimum range.
It seemed like it was getting to much oil at the start and burnt it off when it fired up. Once running it ran perfectly normal.
The other thing I should mention is the starboard cable is slightly off from the port cable. Could that be the issue as the control may look to be in neutral but may slightly be in forward or reverse? Anyone know how to adjust the control cables?
Any help or opinions would be greatly appreciated. Thanks!
