- Jan 31, 2005
Hi,
I noticed on two occasions now that when my engines (Yamaha F250s 1996) were up in the locked position the starboard trim motor would run.
I tried the button on the side of the engine, and it would stop when depressed (either way) but once released it would still run. Same thing when I used the single switch for both motors on the throttle stick. When I press the trim switch for the engine in question (top section of controls) it then stops and everything works normally.
It happens very infrequently so it has been tough to diagnose. Maybe a wiring or logic issue?
Any thoughts appreciated.
