My First Grady
tcontic
After selling my Sea Ray, it's time for a real boat. I've started my search for a great fishing/family boat and a G/W seems to be one of the best options.
My criteria are as follows:
- It has to be fishable, mostly inshore but I'd love to have offshore capabilities
- Trailerable, I'm keeping it at my house for the foreseeable future
- Outboard engines, I'm done with I/O's
- No bottom paint, but I'm wavering on this one
- A cuddy is not necessary but I like it for storage and a head
- At least one comfortable seat for my wife
Budget is firm at 20K
This one seems to fit, opinions are appreciated
http://www.oceanoutboardmarine.com/...30636X10K6K2009J8I56I48JPMQ5067R0&veh=1414275
Welcome to the forum. You've come to the right place.
Nice looking boat there. If you're serious be sure to get it properly checked out by a good marine surveyor.
If it doesn't have a trailer figure about 5 g's for a new one. Maybe find one used.
Watch out for boats caught by the hurricanes down there.
Price includes a new aluminum bunk trailer, this particular boat is a repo. Anyone down in FL feel like giving her a once over before I fly down?
Thanks,
Tom
Make sure the motor condition is everything you think it's suposed to be, a new motor will cost more than you are paying for everything and will depreciate to 50% in less than 3 yrs.
Hull needs to be checked out also.
Good luck.
The Gulfstream is a great boat! That's a terrfic price for a 98, especially with a trailer included.
Do they know how many hours on the motor?
Repo's scare me for one reason... "was anything sabotaged".
As CJBrown said... get a survey, (3rd party). Always worth it.
I had a 91 with the same single engine, (250 ox66). Many will say that boat needs twins. Yea, it would be better, but I was very happy with the single set up. Got up on plane easily and performed fine all-around. A little on the thirsty side, (because of the weight). Cruise at 4400 rpm was around 28 mph and burned around 15 gph, (light load).
Good luck. :D
My concern with this opportunity is that it looks almost too good! At that price my question would be, “what’s wrong with it?” I have a ’97 GS with a Yamaha 250 and know what I paid for mine, and it was significantly more than what this is advertised for. There may be reasons for this and maybe that’s the whole repo issue, but just know you’ve got to go into this with your eyes wide open.
In addition to what the others have stated, the hull and engine have to be… absolutely have to be, in very good to excellent condition. If they’re not, fixing those conditions will quickly drain your bank account. I’d get a certified Yamaha mechanic to inspect the engine. You also need to read all the threads about Gulfstream’s and single engines vs. twins and decide if 250 is enough HP for you.
Even before a survey, I’d get a flash light and stick my head in every nook and cranny I could. Pop open all the deck plates, stern seat and lockers and look for signs of water, mildew, (the cabin windows have a history of leaking) sniff for gas or oil leaks, check every hose you can. Are the connections tight, do they show any signs of deterioration? Replacing those is either expensive and / or difficult.
Electronics, all pumps, wiring connections and trim tabs would be next on my hit list for review. Make sure you know where they all are and that they work. While these are not deal breakers, if you need to fix or replace them it will cost you.
Thru hulls, are they plastic or stainless steel? (I think in ’98, they changed out to SS, so that’s good.) If they’re plastic, are they cracked? They’ll need to be replaced.
The GS has a main and aux gas tank. How old is the gas in there? You may need to have it pumped out and then the tanks cleaned. (you don’t want that bad gas running through your engine) Another PITA. Does the boat have any associated records? Do you know how many previous owners?
Trailer. When was it last inspected? You’ll have to have it inspected in your home state, and the guy that inspected mine, didn’t cut me any slack and in retrospect nor should he have. How will you get it there? New tires? Brakes? Maybe new lights? Grease bearings.
What’s the condition of the curtains, eisenglass, cockpit bolsters, cushions and interior bedding? Figure on new batteries and several hundred dollars at the boat store of your choice for cleaning / detailing products and you’re in business. That’s enough to get you started.
When Grady rolled that boat into the show room it was in near perfect condition. What’s happened to it since, will determine if you still want it. Good luck.
PS- lastly it may depend what your definition of off-shore is, but I’d be very hesitant to take a single engine out off-shore.
I had a friend take a look at this boat last week, seemed to pass an initial inspection. He took some pictures, have a look. Boat also comes with a brand new trailer. Next step it to get a survey and engine inspection by a Yamaha mechanic. It's a repo, the cushions and bolsters were sent out to be recovered, I guess they were in rough shape.
Anyone no a good mechanic and surveyor in the Fernandina Beach, Florida area?
Here's the ad
And some new pictures
What is the cutout for in the transom in the last picture?
