NEED A BUFFER AND WHAT BRAND IS SUGGESTED
can129
NORFOLK, VA (LITTLE CREEK)
I HAVE SEARCHED AND READ MANY OF THE OLD POSTS CONCERNING BUFFERS. I HAVE NOT BEEN ABLE TO LOCATE ANY OF THE HEAVY DUTY ONES AT MY LOCAL STORES TO ACTUALLY TOUCH ONE. I CAN ONLY FIND THE LIGHT DUTY ONES THAT ARE PRIMARALY FOR CARS AND THEY ARE USULALLY HEAVY AND HARD TO HANDLE. WHERE WOULD ANYONE SUGGEST TO BUY ONE AND DO YOU ACCTUALLY NEED ONE THAT IS ORBITAL?
gradytom
lake st. clair
Harbor Freight
An automitive orbital would work well.
Spend $$ on microfiber pads etc.
No real need for a "heavy duty" IMO.
sel1005
FL
I use the Shurhold Orbital buffer, totally different than others but it eliminates any "amateur" usage..... ie, me......
rather than just polishing in a circle, the Shurhold does random patterns. For professionals, it may not be needed, but for people like me, ie, amateurs, that need something pretty "goof proof", the Shurhold polisher is ideal. Its easy, light to use, and I find I can work on the boat and not worry about angles, pressure, all that, and yet get a professional result each time I use it.
richie rich
south windsor, CT
I use Makita, variable speed from Coastal Tool....its not a DA, but does a very nice job......the type of pad makes a difference as noted
Strikezone
Charleston, SC
I also use the Harbor Freight buffer. You really can't beat the price. Just make sure you purchase some good pads.
Parthery
Atlanta, GA
I have a Ryobi DA Orbital I purchased in Home Depot. Its a little heavy, but it was a lot less $$$ and works well.
The pads make a huge difference...order the microfiber ones.
NOTHING ELSE MATTERS
LONG ISLAND NEW YORK
O.K, stupid question, where do i get the microfiber pads? I never saw them locally, i do use the microfiber cloth for cleaning and hand buffing and is amazing.
little jenny
long island new york
i bought the harbor freight buffer a few years ago it works great and has a variable speed dial on the handle. you can get replacement pads at most any hardwarestore
Grady678
Atlanta / Hilton Head, SC
Autogeek.Net sells everything you'll need for buffing equipment.
Tucker
Port Deposit, Maryland
Does anyone know if there is a tutorial about how to use a rotary buffer. I bought one over the winter and with all this talk about burning the gelcoat, I've become quite tight-ass about screwing things up. Also, how does one clean the used microfiber bonnets? They're too expensive to throw away.
Bama96
Birmingham, AL / Destin,FL
Tucker said:
Does anyone know if there is a tutorial about how to use a rotary buffer. I bought one over the winter and with all this talk about burning the gelcoat, I've become quite tight-A** about screwing things up. Also, how does one clean the used microfiber bonnets? They're too expensive to throw away.
Get a Random Orbital you won't burn the gelcoat. Easy to use for a novice.
Frank
I have the Porter Cable 7336/7224 and recommend it highly. It is a random orbital buffer. It is highly regarded and recommended by a lot of people who use it on a professional basis (e.g., a lot of automotive detailers).
can129
BOUGHT A BUFFER FROM AUTOGEEK
AFTER REVIEWING ALL POSTS AND SEARCHING THE OLD POST I BOUTHT THE PORTER CABLE FROM AUTOGEEK. THEY WERE VERY HELPFULL IN DETERMINING THE PADS AND ITS USE. I HAVE ALREADY CLEANED MY BOAT WITH SEAPOWER ONE STEP AND THE BOAT LOOKS GREAT. IT COULD USE A SECOND COAT BUT MY TIME WAS LIMITED SINCE I ALSO REPOWERED WITH A NEW YAMAHA F250 AND WANTED TO GET IT IN THE WATER TO START BREAKING IT IN.
THE BUFFER WAS EASY TO USE AND DID NOT KILL MY ARM AND SHOULDER. I FEEL COMFORTABLE THAT I PURCHASED THE RIGHT PRODUCT.
bhemi
Porter Cable
I use a Porter Cable. Only downside is that it's a touch heavy but it will out last me.
All kinds of detailing websites and forums are out there. I use mine on my car too and car paint is a lot less forgiving than gelcoat.
