Hello - I just got done installing new tanks in my 1999 GW Bimini 306. Here is the original thread where I show the before & after pics and process.
Unfortunately after launching and fueling up, neither tank is registering fuel. I could really use some help here. I have to tell you I am a bit nervous about wiring to 300 gallons of fuel.....
I will post the before and after pictures. Excuse the use of the same yellow wire on the new installs, but I think you can visually trace them back to the original colors. Also below is the GW wiring spec, but I'm still confused.
Appreciate any help on this. Thanks in advance.
Ed
This is my original fwd tank
This is my original rear tank wiring. Note different sender and wiring.
This is my new fwd tank wiring
This is my new rear tank wiring
This is what GW offers for wiring specifications - which does not make sense to me.
Here is wiring diagram from user manual
1999 Bimini 306 - replacing fuel tanks.
Lesson learned. The fuel tanks need to be rinsed regularly, and the deck plate o-ring seals are prone to leaking. I have had this boat since 2005. About 5 years ago, I pulled the deck plate to have a look underneath. I saw A LOT of white jelly. Sadly - I thought that jelly was a protective...
www.greatgrady.com
Ed
