- Feb 15, 2025
- Age
- 65
- Freedom 325
I have a 2019 235 Freedom with a 300 Yamaha. I finally was able to get my lift repair after hurican Milton. After i lowered the boat I tried to start it on number one battery and it did nothing. I switched it to number 2 and it started. the batteries were the originals so I decided to replace both of them. I replaced both with 27M AGM batteries. The same that came with the boat. I cleaned up the terninals with a wire brush wheel on a drill before making the conections. There was evidence of Green corrosin at the old conections. I feel the number one battery was dead because water probaly rose high enough to come in through the drain plug hole during the huricans and the bigle pump ran along time.
Now after putting in the new battereis it just clicks on battery 1 or 2. I tested the batteries and one has 12.9 volts and the other 13.1 volts. the trim also just clicks. I have checked the continuity of the positive batteriey wires from the batteries to the battery switch as well as the short negative that contects the two batteries. the main gound apperars clean and i cant tell where it goes. I also have 12.8 volts on the positive wire where it connects on the motor from the battery switch. I graetly appreciate any of help and suggestions
