- Oct 12, 2017
- Manasquan Inlet NJ
- Website
- www.youtube.com
- Express 265
I've been troubleshooting one of my 225s.
It had been running with even throttles but "stumbling" once in a while. I replaced the VST filter and that seemed to be fixed. About a week later we started with a similar problem
I have to advance the throttle further than the other to get same rpm and it tops out sooner and sometimes it jumps up or back down.
It also coughs out at idle a lot more than usual.
Verified I have spark on all cylinders.
Compression on all cylinders of both motors are 90, give or take 1.
Swapped all spark plugs from one motor to the other during the compression check process. Problem did not move to other engine so that rules out spark plugs.
I have repaired a funky connection of a coil that tricked me into thinking it was better for a run. Maybe it was a contributing factor. I ordered a replacement coil just to have for troubleshooting.
After multiple high speed runs in the river with the cover off we think its fuel flow.
I pulled out the injectors and will send them off to fuel injector man. (I think someone here recommended him)
First time ever doing this but it was quite easy.
I am also ordering a filter screen that goes between the pressure regulator and the fuel rail.
Can't seem to get the old one out easily. Will probably destroy it getting it out so I want a new one on hand first.
