Paint on Cushions?
Halfhitch
Venice, Florida
I Recently purchased a 2004, 228. The previous owner who lives in S. Florida wisely kept the cushions in his garage when not in use in an effort to keep the mold/mildew at bay.
The day before I was to come over for a sea trial the owner was working so he ask his wife to get the cushions out and make sure they are all there. When she got them out and was looking them over she thought they didn't look as white as they should. She didn't know they are not supposed to be bright white. She thought they had darkened from age and did a search on google about how to clean boat seats. She just happened to read one of those articles about spray painting the vinyl to make them look new. Bless her heart, she thought she was helping. The cushions were in decent condition till she did that. Well, except for the rear backrest cushions. He had to learn the lesson about not towing with them in place the hard way. None of the piping is worn and no ripped seams. Now they have a creepy feel to them and she must have bought the cheapest paint available because in the high humidity we have, the surface continues to have a sort of tacky feel. When they touch together for awhile, like when you stack them, they kinda stick together. I am hoping someone here knows how to remove the paint without damaging the vinyl. I have some Citrus paint stripper but that says not to use it on vinyl. It's talking about house siding but no doubt, vinyl is vinyl. Thought about acetone but I'm not sure how that would affect the material either. If you have knowledge about this, please help.
You can see they are too white.
Here, you can see here where it stuck to another cushion and pulled off some paint showing the factory color underneath.
On this one, she forgot to spray the backside so the original color is obvious.
Definitely don't use acetone! You MIGHT be able to use it sparingly, but you run a good risk of damaging the vinyl. Naptha is safe for vinyl, but I'm not sure how well it's going to take the paint off if it's cured. That's the hard part - the paint is cured - or at least mostly, it sounds like. Paint thinner should be fine, as well. Try laying a white rag onto a spot on the cushion for about 10 minutes to see if it softens the paint. Start with safe things and work your way up. In the end, you may just have to re-cover. As a last step, before recovering, try SEM vinyl paint. Roughen the surface up with a scotch pad, first.
Halfhitch
Venice, Florida
Thanks Dennis, I agree about the hard part being not screwing up the vinyl. I will get some paint thinner and try your suggestion.
When I saw the cushions, I could've cried but the boat was in decent shape, so I wasn't going to let the vinyl condition wreck the deal, even though it is gonna cost some dough if I have to recover. The people that owned it were not boat people to say the least so it's understandable how this happened.
They weren’t painters either, so before I put any paint thinner on that vinyl, I would hope that maybe she used a latex paint. Try hitting it with a pressure washer, if you don’t have one take it to the car wash and blast it with the hose
Prob best to recover or have new ones nes made. Could spend a ton of time and/or money with those.
In some cases, vinyl cushions can be painted with spray paint that is intended for such an application. In this case the paint that has been applied probably has ruined the cushions. If you want to try to restore, I would use a citrus based paint remover (tested in a non conspicuous spot first:)), scrub as mentioned and then it the vinyl looks shot, use the vinyl spray.
I had an old boating buddy who painted his cushions using Rustoleum and they came out better than you would think. The paint job lasted a season or two.
trapper
John, there is a product called easy EZ strip all purpose remover that might be worth a try.
Our low VOC Eco-friendly formulas clean up with just water providing The Safer Option for coating removal.​
Halfhitch
Venice, Florida
Thanks Trapper. I will look into that. I was about to try Glacierbaze idea of using a pressure washer. If I turn down the pressure to the lowest pressure setting, maybe it won't destroy them. I will get some of that EZ Strip first and give that a go.
Halfhitch
Venice, Florida
I couldn't find that exact brand but after reading about its attributes, and being water based, I found some similar stuff here. I tried it and I took a chance and used some citrus also figuring if I didn't leave it too long and flushed good with water I should be OK. They both worked. They destroy the bond of the paint to the strata. I just did a test on the corner of one cushion but I will get set up to do a couple cushions at a time so I can keep tabs on any adverse effects. I will attempt to attach a video.
............................I couldn't figure out how to upload a short phone video so I'll just say, it looks like I will be able to save the cushions.
wrxhoon
Sydney Australia
Depending on what paint she used hot water could soften the paint ( close to boiling point) and then easier to remove.
Looking at the cover that the paint has lifted, she didn't prepare the vinyl before painting, should be easier to remove.
Halfhitch
Venice, Florida
I think you are right about the boiling water. The film of paint peels of easily once the paint remover works on it for a few minutes. I tried to upload a short video but I'm not smart enough. I robbed a couple of stills out of the video.
wrxhoon
Sydney Australia
You are lucky, she didn't prepare the surface before spraying it! You will spend a bit of time but should all come off.
