Parts Assist Pls
Dieler
Have a 265 Express and looking for to source the following parts. Have searched forum and internet with little luck. Any assist appreciated.
a) Have a plastic dome light assembly under the hardtop electronics box. There is a white and red bulb in the dome on one switch and another switch for the spreader lights. I need to replace the switch itself on the dome assembly for the interior light, it has simply stopped working. Appears to be a simple push activated plastic switch w/ rubber covering.
b) The fresh water supplied sink has a hose and handle assembly. The handle itself is old and does not close to stop the flow of water when the system is pressurized. I was told at a local marine store that the nozzle is not sold separately and I need to buy the nozzle and hose assembly to install. Have had zero luck finding this assembly.
Thanks in advance for any assist
G8RDave
Tampa, Florida
You can get the switches at Digi-Key. The switch for the dome light with red and clear bulbs is #522PB-ND. The one for the spreader lights is #512PB-ND. That is assuming you have the same switches as I do on my 228.
If your fresh water sink uses the same assembly as my fresh water wash down, I can get you the info on that as well (had to replace mine awhile back).
Dieler
Very nice - greatly appreciated. Found the switch, looks right. If you do have info on the washdown that would be a bonus
Thx again
G8RDave
Tampa, Florida
The direct replacement for my transom shower was from Scandvik. A quick search should turn up lots of options for you. I know Defender carries Scandvik as do others such as Jamestown Distributors. But yes, I think you will need to order the full assembly.
Dieler
Thanks much - will track it down, greatly appreciated
