- Nov 19, 2021
- Tournament 192
I just drained old fuel from my 1996 Tournament 192.
I connected a fuel hose to the tank pickup tube and used a bulb to get things going, expecting a solid siphon. I did get fuel out when I pumped the bulb, but the siphon wouldn't hold up after I stopped.
I then removed the sender, dropped the line into the tank, pumped the bulb, and the siphoned continued on its own without issues.
Would the failure to siphon through the pickup tube indicate a restriction, or maybe a leak above the fuel level in the tank, or is there something in the pickup tube construction that would explain this? Anyone know?
Thanks,
T.
Thanks,
T.
