Power bimini top adjustment
Pembroke
Kitty Hawk, NC
Our 2023 235 Freedom has a Sure Shade power bimini. The left side fixed tube is sitting out about 6 inches more than the right side tube which is at the correct distance. Is there an adjustment under the cowling that covers the power tubes? Will I be able to make this adjustment if I pull off the cowling which is sealed up with caulk. It is as if it was not installed correctly or someone pulled it out somehow.
