Power Pole for GW Fisherman 216
Piankitank
Has anyone found an effective way to mount a power pole on this model GW? Issue is the swim brackets extend past the motor which precludes the use of PP's standard mounting hardware. Wondering if the addition of a jack plate with offset of 6inches or more might push the outboard far enough back to where I could use Power Pole's engine bracket. The folks at Power Pole were not able to provide a solution.
