1985 20' overnighter I guess it weights about 4500#. Ready to put a power winch on the trailer. Any suggestion?
seasick said:I don't think that vessel weighs 4500 even with fuel. Regardless, the winch doesn't pull the boats weight since it is pulling the boat at an angle much less than 90 degrees ( over a cliff).
Yes you can buy a bigger winch but I think that is a waste of money. The larger capacity ones don't necessarily winch faster and may in fact winch slower due to higher reduction gear ratios. So give a call to the winch manufacturer or a reputable trailer distributor and tell them your vessel weight and the type of trailer and let them size a winch that is appropriate.
Bill_N said:seasick said:I don't think that vessel weighs 4500 even with fuel. Regardless, the winch doesn't pull the boats weight since it is pulling the boat at an angle much less than 90 degrees ( over a cliff).
How many have you had? I've owned three. They work great but they put a big load on your trucks alternator. At one point a friend and I had the same boat and similar 1/2 ton trucks but he had a small winch that burned out his alternator a few times and at that point you're hand cranking which sounds easy but really isn't on a powerwinch.
