I'm going to have to surrender on this one, I am going to tow it to the dealer in a couple hours. I almost had fished the rope through from the tank to the starboard side fuel fitting with fish tape then I dropped my magnetic pickup tool and it disappeared into the fuel line black hole. :jaw A search was initiated but no survivor found, RIP. Anyway at this point the dealer is local and has a very good reputation. They can cut as many access holes as they need to fix this, huge pita but at least I learned my lesson the hard way.
I've been working on the boat off an on for a couple months now and have not been on the water yet. Being a new first time boat owner of a 20 year old Grady, its a bit overwhelming. So far I have performed a tune-up, changed t-stats, new wires, rebuilt carbs, added new carb fuel lines and from tank to motor, gaskets, water pump, de-carbed system, added a missing spark assembly to adjust idle, new scuppers and scupper lines, new battery cables, new fuel and oil line filters.
Most of my problems at this point are wiring related which I'm not very good with. I would like to use a Blue Sea fuse block setup, will bounce some ideas with the dealer. Thanks for the help, I've learned a lot from this forum!
