Hi - I recently changed the props on my 1994 252 Sailfish from 14 3/4” diameter 19” Evinrude Viper to 15 1/2” diameter 17” pitch Evinrude Rebels. The Vipers are designed for "All-around General Purpose" use while the newer bigger Rebels are designed for "Faster Cruising Speeds and Improved Fuel Economy." I made the change because I wanted the reported better low-speed planing performance which I have realized. Prior to the change the boat would fall off plane too easily at slower speeds. I wanted to understand this better so I made a plot of propeller slip percentage for the two props and see that the old props where slipping a whole lot more then the new props - especially between 3000-3500 RPM where I was having planing issues. The larger Rebels just seem to hold better. Other vitals are that my WOT RPM increased from 5650 to 5850 RPM (light) and max speed dropped from about 50 to 48 MPH. The MPG increase was marginal - maybe about 0.1 at cruise.
Is there a similar propeller style choice that has to be made for Yamaha motors for similar applications?
Cheers,
-Scott
Cheers,
-Scott
