- Oct 31, 2021
- Age
- 47
- Maryland
- Explorer
Going to be replacing all the thru hulls and scuppers, hoses, clamps, raw water pick up are getting moved. All of them on the outside of the boat will be off.. They are 30 years old and cracked. Also going to be 100% removing the ablative bottom paint and will be painting with Interlux VC performance Epoxy. Boat is going from wet slip to dry rack/trailered so I do not need the antifoul properties.... At most once or twice a year it will be wet slipped for a week at a time. Here is my question..... A few of the thru hull and scuppers are right on the water line and pickups are obviously below the water line. Do I paint with epoxy and then install the thru hulls or install the fittings against the gel coat and paint around them? I have not found the proper way.... or if it even matters. Opinions are welcome.
